Place a display, up to 30" in size, at your desk, using this height-adjustable monitor mount with integrated cable management. The adjustable monitor stand lets you mount a display on your desk, with tilt, pivot and height adjustments for perfect positioning. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The monitor stand holds most common displays with ease, supporting monitors from 12 - 30" up to a maximum weight capacity of 30lbs (14kg). For added flexibility, the included hardware can be used to mount your Apple iMac or Apple Cinema Display.
The desktop monitor stand features a 15in (380mm) tall support post, for a much greater range of height adjustments than typical monitor stands can provide. For viewing longer pages or blocks of code without scrolling, the LCD stand also supports landscape to portrait display rotation.
Adjust your display height, position and viewing angles easily to create an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk by mounting on a support post above the desk surface.
- StarTech.com Single Monitor Stand - For up to 34" VESA Monitors - Silver - mounting kit
- Product Type
- Mounting kit
- Mounting Components
- Desk stand, feet, wrench, screws, cable clip
- Adjustments
- Pan, tilt
- 3.3 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 12"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 14 kg
- Material
- Plastic, steel
- Silver
- 5-year warranty
- 3.3 kg
- Material
- Plastic, steel
- Silver
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 12"-30"
- Adjustments
- Pan, tilt
- Max Load Weight
- 14 kg
- Adjustable height, portrait to landscape movement, swivel adjustment, pivot
- Limited warranty - 5 years
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £67.48 |
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount | In Stock | £64.11 |
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook | In Stock | £55.46 |
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit | In Stock | £73.16 |
StarTech.com Articulating Monitor Arm | In Stock | £101.86 |
StarTech.com DVI Laptop Docking Station | In Stock | £66.45 |
StarTech.com 4K DP Laptop Docking Station | In Stock | £99.36 |
StarTech.com USB-C Multifunction Adapter 4K | In Stock | £54.49 |
StarTech.com Monitor and Laptop Arm | In Stock | £87.11 |
StarTech.com USB-C Multifunction Adapter | In Stock | £60.65 |
