StarTech.com Desk Mountable Tablet Stand
Quicklinx: BKBVWS00 Mfr#: ARMTBLTI
Securely mount a 9-11" tablet to a desk, with extension, tilt, pan, swivel, pivot and height adjustments. This universal tablet stand lets you integrate your tablet seamlessly into any workspace by clamping it to your desktop or countertop work surface.
With this highly adjustable tablet stand, you'll be able to integrate your tablet into your workspace for maximum comfort and convenience. The stand features an articulating arm that enables you to easily position your tablet at the perfect height and depth for any application. The tablet holder rotates 360 degrees and can tilt and swivel for optimal position. The tablet holder also has a lockable switch that lets you ensure your tablet is properly secured.
You can easily secure this tablet stand to your work surface, by clamping it onto your desk or countertop. Plus, the built-in arm discreetly manages your charging cable for a tidy, professional workspace, that enables you to charge your tablet while it's mounted. The tablet holder features a claw mechanism that lets you easily remove and remount your tablet with ease.
This sturdy tablet holder ensures a secure home for your tablet with a solid-steel design that won't drop your tablet if it's bumped or knocked. The tablet stand combines this durable design with a sleek, professional finish that will look great in your home, office or storefront.
  • Customizable positioning
  • Hassle-free installation
  • Maximum durability
StarTech.com Desk Mountable Stand for iPad or Android Tablets mounting kit - adjustable arm - for tablet - black
Mounting kit (adjustable arm) - desk-mountable
Mounting Components
Desk clamp mount, wrench, cable management clip, EVA cushion, security wrench
Tilt
180°
Pan
280°
Rotation
360°
Adjustments
Height, lift
1.774 kg
Recommended Use
Tablet
Recommended Display Size
11"
Max Load Weight
1 kg
Material
Steel
5-year warranty
1.774 kg
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Design
Adjustable arm
Recommended Use
Tablet
Placing / Mounting
Desk-mountable
11"
Tilt
180°
Pan
280°
Rotation
360°
Adjustments
Height, lift
Max Load Weight
1 kg
Limited warranty - 5 years
