StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors
Quicklinx: FF59WS00 Mfr#: ARMDUALPS
Accessory Type: Mount
£213.61 ex VAT
£256.33 inc VAT
Create an ergonomic workspace with this premium desk-mount dual monitor arm, for monitors up to 27" each. The two articulating monitor arms with dual-swivel action offer a wide range of motion side to side. The attractive silver finish enhances the aesthetics of your workspace.
The dual articulating monitor arms offer a wide range of motion on several axes. It provides effortless motion to adjust the position of your monitors.
The robust aluminum design provides stable support for your monitors. The computer-monitor desk mount supports two VESA mount monitors (75x75, 100x100) with a weight capacity of up to 22 lb. (10 kg) per display. The cable-management channel helps to keep your workstation neat and tidy.
Share your screen with ease. The double monitor mount offers a full +180-degree / -180-degree pan, to move your screen left or right. It tilts freely +90 / -15 degrees to adjust the angle up or down. Rotate your screens for landscape or portrait viewing.
Work in comfort. This height-adjustable monitor mount lets you raise or lower the monitor arms along the pole, with a range of up to 6.3" (160 mm).
The fully assembled desk clamp and pole, plus quick slide-and-click connections, ensure easy assembly. It also saves time when setting up multiple units. The dual-screen mount gives you the option of desk clamp or grommet hole mounting (hardware included).
  • Enjoy a Wide Range of Motion to Work in Comfort
    The?dual articulating monitor arms?offer a wide range of motion on several axes. It provides effortless motion to adjust the position of your monitors.
  • Sleek and Stable Aluminum Design
  • Adjust your Viewing Angle
  • Height Adjustment
  • Tool-less Assembly
    The fully assembled desk clamp and pole, plus quick slide-and-click connections,?ensure easy assembly. It also saves time when setting up multiple units. The dual-screen mount gives you the option of desk clamp or grommet hole mounting (hardware included). The TAA compliant?ARMDUALPS?is backed by a StarTech.com 10-year warranty and free lifetime technical support.
StarTech.com Desk Mount Dual Monitor Arm, Premium Articulating Monitor Arm, up to 27" VESA Mount Displays, Height Adjustable Monitor Mount, Rotating/Swivel/Tilt, Desk Clamp/Grommet, Silver - Easy & Quick Assembly (ARMDUALPS) mounting kit - adjustable arm - for 2 LCD displays - silver - TAA Compliant
Mounting kit (adjustable arm) - desk-mountable
19 cm x 22 cm x 52 cm
Tilt
-15° to 90°
Pan
-180° to 180°
Rotation
360°
Adjustments
Height, pan, tilt, rotation
5.7 kg
Recommended Use
2 LCD displays
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Aluminium
Silver
TAA Compliant
Package Content
2 x VESA monitor mounts, desk clamp, EVA cushion, cable management clip, thumbscrews, 4 x swivel arms, shoulder, pole assembly, 2 x M3 hex keys
5-year warranty
19 cm
22 cm
52 cm
5.7 kg
Material
Aluminium
Silver
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
13"-27"
Tilt
-15° to 90°
Pan
-180° to 180°
Rotation
360°
Adjustments
Max Load Weight
10 kg
TAA Compliant
Dimensions & Weight Details
14.5 cm x 33 cm x 46.5 cm / 5.8 kg
Limited warranty - 5 years
FF59 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
FF59 StarTech.com Monitor Mount - USB Passthrough In Stock £176.82
FF59 StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
FF59 StarTech.com Vertical Dual Monitor Mount In Stock £76.91
FF59 StarTech.com Thin Client Mount - VESA In Stock £26.25
FF59 StarTech.com Desk-Mount Dual-Monitor Arm In Stock £104.33
FF59 StarTech.com Desk Mount Dual Monitor Arm - Crossbar In Stock £100.55
FF59 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.65
FF59 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.93
FF59 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.94
