StarTech.com Dell EMC SFP-1G-BX80-D Downstream SFP Module
Quicklinx: FHLKWS00 Mfr#: SFP1GBX80DES
The SFP1GBX80DES is a Dell EMC SFP-1G-BX80-D compatible downstream fiber SFP transceiver which pairs with StarTech.com's SFP1GBX80UES. They are designed, programmed and tested to work with 1000Base-BX80 compatible Dell EMC switches and routers. The SFP transceiver module supports a maximum distance of up to 80 km (49.7 mi) and delivers dependable 1 GbE connectivity over fiber cabling.
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC SFP-1G-BX80-D Compatible SFP Module, 1000BASE-BX-D, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC 80km, Mini GBIC Transceiver SFP, Downstream - Lifetime Warranty (SFP1GBX80DES) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX80-D
Data Transfer Rate
1 Gbps
Optical Wave Length
1550 (TX) / 1490 (RX) nm
GigE
Max Transfer Distance
80 km
5.84 cm x 1.39 cm x 1.26 cm
30 g
Plug-in module
Wired
Cabling Type
1000Base-BX80-D
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
80 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-BX80-D - LC single-mode female
MTBF
3,713,222 hours
FCC, RoHS, REACH, MSA
5.84 cm
1.39 cm
1.26 cm
30 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
