StarTech.com Dell EMC SFP-100M-FX Compatible SFP MM Module
Quicklinx: FHKKWS00 Mfr#: SFP100MFXEMS
£42.34 ex VAT
£50.80 inc VAT
The SFP100MFXEMS is a Cisco SFP-10G-ZR-S compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 100 MbE connectivity over fiber cable, for 100Base-FX compliant networks, with a maximum distance of up to 2 km (1.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC SFP-100M-FX Compatible SFP+ Module - SFP+ transceiver module - 100Mb LAN
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
5.84 cm x 1.39 cm x 1.26 cm
30 g
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 100Base-FX - LC multi-mode female x 2
MTBF
1,472,572 hours
UL, FCC, MSA
5.84 cm
1.39 cm
1.26 cm
30 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Price Range Ex VAT: 0 - 50
