The SFP100MFXEMS is a Cisco SFP-10G-ZR-S compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 100 MbE connectivity over fiber cable, for 100Base-FX compliant networks, with a maximum distance of up to 2 km (1.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Dell EMC SFP-100M-FX Compatible SFP Module, 100BASE-FX, 100MbE Multi-Mode Fiber MMF / Single Mode (SMF) Fiber SMF, 100Mb Ethernet SFP, LC Connector, 2km, 1310nm, DDM, 100Mbps - Lifetime Warranty (SFP100MFXEMS) - SFP+ transceiver module - 100Mb LAN
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- OEM Manufacturer Equivalent Part Number
- Dell EMC SFP-100M-FX
- 5.84 cm x 1.39 cm x 1.26 cm
- 30 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 2 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 100Base-FX - LC single-mode female
- MTBF
- 1,472,572 hours
- UL, FCC, MSA
- 5.84 cm
- 1.39 cm
- 1.26 cm
- 30 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
