StarTech.com Dell EMC AOC-SFP-10G-3M Compatible SFP+ AOC Fiber Cable
Quicklinx: FJBCWS00 Mfr#: AOCSFP10G3ME
The AOCSFP10G3ME is a Dell EMC AOC-SFP-10G-3M compatible fiber optical SFP+ cable that is designed, programmed and tested to work with Dell EMC brand 10 Gb compatible servers or routers and complies with MSA industry standards. This active optical SFP+ cable (AOC) supports 10GbE applications connected through SFP+ (Mini-GBIC) ports and is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions. The AOC cable is lighter and more flexible than SFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances. Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com offers a wide variety of direct-attach SFP cables and SFP modules, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC AOC-SFP-10G-3M Compatible 3m/9.84ft 10G SFP+ to SFP+ AOC Cable, 10GbE SFP+ Active Optical Fiber, 10Gbps SFP Plus/Mini GBIC/Transceiver Module Cable, Mini GBIC Cable - Lifetime Warranty (AOCSFP10G3ME) - Ethernet 10GBase cable - 3 m
Fibre optic
Active Optical Cable (AOC)
Length
3 m
Connector
SFP+ - plug - latched
Connector (Second End)
Network Cable Type
Fibre optic
Length
3 m
Connector
UL, FCC, RoHS, REACH, MSA
Shipping Width
24.7 cm
Shipping Depth
32.4 cm
Shipping Height
10 cm
70 °C
