Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has a 4-pin DIN barrel and requires 12 volts and up to 6.5 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
This power adapter is a direct replacement for the power adapters included with the following StarTech.com products: USB 3.0 / eSATA 4-Bay 3.5in SATA III Hard Drive Enclosure (S3540BU33E); 1U Rackmount 4-Bay 3.5in SATA / SAS External Hard Drive Enclosure (SAT35401U); 4 Bay eSATA USB 3.0 to SATA Hard Drive Docking Station (SATDOCK4U3E); 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock (SATDOCK4U3RE); USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station (SDOCK4U33).
- StarTech.com 12V, 6.5A DC Adapter - Universal - 78W - DC Adapter - Power Adapter (SVA12DN4NEUA) - power adapter
- Power adapter - external
- Localisation
- Australia, Japan, United Kingdom, Europe, North Asia
- Input Voltage
- AC 120-230 V
- Output Voltage
- 12 V
- 2-year warranty
- Designed For
- P/N: S3540BU33E, SATDOCK4U3RE, SDOCK4U33
- Localisation
- Input Voltage
- AC 120-230 V
- Output Voltage
- 12 V
- Max Electric Current
- 6.5 A
- Cables Included
- Power cable - external
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 80%
- Designed For
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.39 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £411.23 |
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans | In Stock | £141.38 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.06 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £10.25 |
