Product
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F
Quicklinx: 9209WS00 Mfr#: AT925FF
17 in stock
£4.08 ex VAT
£4.89 inc VAT
Convert a DB9 male port to a DB25 female port. The AT925FF DB9F to DB25F cable adapter converts a 9-pin serial port into a 25-pin female port.
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F - serial adapter
Serial adapter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - female
StarTech.com 1, 16, 2, 2 Serial/1, 4, PCI1S650DV, PCI2S650DV, PCI2S650PW, PCI4S650DV
Serial adapter
Connector
StarTech.com 1 Port 16550 PCI Express Serial Card, 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Dual Voltage Parallel Adapter Card, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Powered Serial Adapter Card, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port 16550 PCI Express Serial Card, 2 Port 16650 PCI-E WHQL Approved Serial Card, 2 Port CardBus RS232 Serial Laptop PC Adapter Card - 16950, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port PCI RS232 Serial Adapter Card with 16550 UART, 2 Port USB to RS232 Serial DB9 Adapter Cable, 2 Serial/1 Parallel Port Dual Voltage WHQL PCI Card, 4 Port 16950 Serial CardBus Adapter, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Dual Profile RS232 Powered Serial Adapter Card, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI Express WHQL Approved Serial Card, 4 Port PCI RS232 Serial Adapter Card, 4 port PCI RS232 Serial Adapter Card with 16550 UART, PCI1S650DV, PCI2S650DV, PCI2S650PW, PCI4S650DV
Price Range Ex VAT: 0 - 50
