StarTech.com DB9 to DB25 Serial Cable Adapter - F/F
Quicklinx: 9209WS00 Mfr#: AT925FF
Convert a DB9 male port to a DB25 female port. The AT925FF DB9F to DB25F cable adapter converts a 9-pin serial port into a 25-pin female port.
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F - Serial adapter - DB-9 (F) to DB-25 (F) - AT925FF - serial adapter - DB-9 to DB-25
Serial adapter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - female
P/N: EC1S232U2, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB2328I, ICUSB232DB25, ICUSB232FTN, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, PCI2S1P2, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S952LP, PEX4S553, PEX4S553B, STCPEX2S553
Serial adapter
Connector
P/N: 10PKPCI1S550, EC1S232U2, IC485S, ICUSB232, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328I, ICUSB232DB25, ICUSB232FTN, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, PCI1S550, PCI2S1P, PCI2S1P2, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S952, PEX2S952LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP, PEX8S952, STCPEX2S553
