StarTech.com Cubicle Monitor Mount - With Micro-Adjustment - For up to 34
Quicklinx: FSHSWS00 Mfr#: ARMCBCLB
Accessory Type: Mount
Hurry, only 1 left in stock!
£50.26 ex VAT
£60.31 inc VAT
Free up valuable desk space in your cubicle workstation with this cubicle monitor mount. It lets you mount a monitor on your cubicle wall to keep your work area more organized, comfortable and productive.
The cubicle monitor hanger, made of steel with a metallic silver finish, securely supports a 17" to 34" VESA mount monitor, with a maximum weight of 17.6 lb. (8 kg).
The cubicle wall monitor mount helps you free up surface area in your workspace, and keeps cables neat with integrated cable management.
Adjust your screen height quickly, by pulling the lever while sliding the monitor to the desired height. Up to 12" of height adjustment accommodates a wide range of users.
For customized viewing, tilt your monitor +/-10 degrees and swivel +/-10 degrees. The cubicle monitor mount also rotates +/-180 degrees, for landscape or portrait positioning.
Customize your work area by hanging multiple monitors, using several cubicle monitor hangers to create a multi-monitor workstation. The micro-adjustment feature lets you align your monitors in perfect unison. Plus, angle your monitors for optimum viewing.
The cubicle-wall monitor mount is easy to set up. The monitor mount works in most cubicles, with wall sizes from 1.5" to 3.5" in thickness. It's optimized for wall heights ranging from 19" to 30" above the desk surface.
StarTech.com Cubicle Monitor Mount, Cubicle Wall Single Monitor Hanger, Up to 34" VESA Mount Display, Height Adjustable Ergonomic Office Cubicle Hanging Flat Panel Hook & Clamp Bracket - Landscape/Portrait (ARMCBCLB) - bracket - for Monitor - silver
Bracket - wall-mountable
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
Height, tilt, rotation
Recommended Use
Monitor
Recommended Display Size
17"-34"
VESA Mounting Interface
VESA
Max Load Weight
8 kg
Material
Plastic, steel
Silver
Package Content
4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key, 4 x M4x16 screws, 4 x spacers, EVA pad, 4 x M5x16 screws
Material
Plastic, steel
Silver
Package Content
AV Furniture
Bracket
Recommended Use
Monitor
Placing / Mounting
Wall-mountable
VESA
17"-34"
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
Max Load Weight
8 kg
Limited warranty - 2 years , Technical support - lifetime
FSHS StarTech.com Thin Client Mount - VESA In Stock £26.25
FSHS StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.65
FSHS StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.93
FSHS StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.94
FSHS StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £8.76
