Convert a Composite or S-Video Signal and the Accompanying Audio to HDMI?. The VID2HDCON Composite and S-Video to HDMI? Video Converter (with Audio) lets you connect an S-Video or Composite device, along with supporting 3.5mm audio, to your HDMI monitor or television. Equipped with convenient selector switches for easy configuration, the S-Video/Composite to HDMI converter is able to function with both NTSC and PAL systems, and offers support for output resolutions up to 1600x1200 (PC) or 1080p (TV) to seamlessly integrate with almost any display. The converter features an integrated 3.5mm audio connection that enables sending the output through a single HDMI cable to your destination display, avoiding the hassle of running a separate audio cable.
- StarTech.com Composite and S-Video to HDMI Converter with Audio - Video converter - composite video, S-video - HDMI - black - VID2HDCON - video converter - black
- Video converter
- Max Resolution
- 1600 x 1200
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI output - 19 pin HDMI Type A
- 16.3 cm x 16.5 cm x 3.4 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1600 x 1200 at 60 Hz
- 1 x composite video input - RCA - female , 1 x S-video input - 4 pin mini-DIN - female , 1 x audio line-in - mini-phone stereo 3.5 mm - female , 1 x HDMI output - 19 pin HDMI Type A - female
- LED indicator
Video Output
- Analogue Video Format
- NTSC, PAL
- Voltage Required
- AC 120/230 V / DC 5 V
- 2.5 Watt
- Cables Included
- 1 x power adapter
- Plug and Play, FCC, RoHS
- 16.3 cm
- 16.5 cm
- 3.4 cm
- 100 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90%
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV | In Stock | £95.65 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.74 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
StarTech.com Composite and S-Video to HDMI Converter with Audio | In Stock | £122.65 |
StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female | In Stock | £4.20 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £267.59 |
StarTech.com S-Video or Composite to HDMI Converter with Audio - 720p - video converter - black | In Stock | £73.24 |
