Convert between resolutions and video formats with StarTech.com's VID2DVIDTV, a composite/s-video/YCbCr/RGB component to DVI scaler. The VID2DVIDTV automatically detects your source's input resolution and allows you to customize its output resolution and refresh rate through an easy to use on-screen-display menu.
Great for home theatre peripherals like DVD players, the VID2DVIDTV lets you connect non-DVI/HDTV enabled equipment to DVI or HDTV display devices like flat panel monitors, DVI projectors and plasma screen TVs.
- StarTech.com Composite and S-Video to DVI-D Video Converter with Scaler - video converter - 48 MB - black
- Video converter
- Memory
- 48 MB
- 1 x DVI-I output - 24+5 pin combined DVI , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x RGB input - 8 PIN mini-DIN , 1 x component video input - RCA x 3 (with adapter) , 1 x DVI-D output - 24+1 pin digital DVI (with adapter)
- 7.7 cm x 14.6 cm x 3 cm
- Enclosure Colour
- Black
- Designed For
- P/N: DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, SVA5M3NEUA
- Video converter
- 1 x DVI-I output - 24+5 pin combined DVI - female , 1 x S-video input - 4 pin mini-DIN - female , 1 x composite video input - RCA - female , 1 x RGB input - 8 PIN mini-DIN - female , 1 x component video input - RCA x 3 (with adapter) - female , 1 x DVI-D output - 24+1 pin digital DVI (with adapter) - male
- Size
- 48 MB
Video Output
- Supported Display Graphics
- VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), HDTV (1920x1080), HD (1280 x 720), 720x480, 1280x768, 720x576
- Analogue Video Format
- NTSC, PAL
- Cables Included
- 1 x component video adapter , 1 x composite video cable - 91.44 cm , 1 x DVI-I to DVI-D adapter - 1.83 m
- 7.7 cm
- 14.6 cm
- 3 cm
- 0.3 kg
- Enclosure Colour
- Black
- Designed For
