StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200
Quicklinx: 8GN6WS00 Mfr#: VGA2HD2
Type: AV Sender
Hurry, only 3 left in stock!
£90.94 ex VAT
£109.12 inc VAT
Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
StarTech.com Component (YPbPr) / VGA To HDMI Converter With Audio - PC to HDMI - resolutions up to 1080p (HDTV) and 1920 x 1200 (PC) (VGA2HD2) - video converter - black
Video converter
1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
7.6 cm x 3 cm x 9.2 cm
Enclosure Colour
United States
Video converter
1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x component video input - RCA x 3 (on supplied cable) - male
1 x component video cable
FCC, RoHS
7.6 cm
3 cm
9.2 cm
190 g
Enclosure Colour
United States
20 - 90%
8GN6 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
8GN6 StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £95.65
8GN6 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £5.00
8GN6 StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 In Stock £90.94
8GN6 StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £43.85
8GN6 StarTech.com VGA to HDMI Scaler - 1920x1200 In Stock £207.80
8GN6 StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £267.59
8GN6 StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered In Stock £44.36
8GN6 StarTech.com 3 m (10 ft.) VGA to HDMI Adapter Cable with USB Audio In Stock £39.35
8GN6 StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio In Stock £32.05
Type: AV Sender
