StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter
Quicklinx: 5JSHWS00 Mfr#: USB2106S
More than 50 in stock
£12.69 ex VAT
£15.22 inc VAT
Add a 10/100Mbps Ethernet port to a USB enabled computer system. This compact USB 2.0 to 10/100 Mbps Ethernet USB network adapter offers convenient Ethernet connectivity - simply connect the network adapter to an available USB 2.0 port on your laptop computer, then connect the adapter to the Ethernet network.
Providing full/half duplex operation on both 10Mbps or 100Mbps Ethernet connections, this USB 2.0 Ethernet adapter supports data transfer rates of up to 200Mbps, providing a fully integrated, cost-effective and reliable solution to notebook users requiring Ethernet connectivity.
StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
2.2 cm x 6.8 cm x 2.6 cm
22 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
IEEE 802.3, IEEE 802.3u
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14
1-year warranty
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Port transmission speed, link OK
Flow control, wake on LAN (WOL), full duplex mode
1 x 100Base-TX - RJ-45 - female
RoHS
Software Included
Drivers & Utilities
2.2 cm
6.8 cm
2.6 cm
22 g
Limited warranty - 1 year
5JSH StarTech.com 1 Port PCI 10/100 Mbps Ethernet Network Adapter Card In Stock £5.64
5JSH StarTech.com 3 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £2.61
5JSH StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter In Stock £12.69
Resources
The following resources are available for the StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter
Price Range Ex VAT: 0 - 50
