StarTech.com Citrix SFP-TX Comp SFP Copper Module - 10/100/1000Base-TX
Quicklinx: FJNYWS00 Mfr#: SFP-TX-ST
The SFP-TX-ST is a Citrix SFP-TX compatible copper transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix SFP-TX Compatible SFP Module - 1000BASE-T - 1GE Gigabit Ethernet SFP to RJ45 Cat6/Cat5e Transceiver - 100m - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 1000Base-TX, 100Base-TX
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
Citrix SFP-TX
6.8 cm x 1.37 cm x 1.38 cm
15 g
HPE Aruba MMC-6000 Multi-Service Mobility Controller Base System
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
100 m
Full duplex mode
1 x Ethernet 1000Base-TX - RJ-45 female
MTBF
510,469,759 hours
FCC, RoHS, REACH, MSA
Citrix SFP-TX
1 Watt
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
