StarTech.com Citrix EW3P0000558 Compatible SFP+ SM Module - 10GBase-LR
Quicklinx: FHJ9WS00 Mfr#: EW3P0000558-ST
The EW3P0000558-ST is a Citrix EW3P0000558 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix EW3P0000558 Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 10km, 1310nm, DDM, Mini GBIC SFP+ - Lifetime Warranty (EW3P0000558-ST) - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
Citrix EW3P0000558
5.84 cm x 1.39 cm x 1.37 cm
21 g
Plug-in module
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MTBF
1,386,624,697 hours
MSA
Citrix EW3P0000558
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
