StarTech.com Citrix EG3B0000087 Comp SFP Copper Module -100/1000/1000Base
Quicklinx: FHHHWS00 Mfr#: EG3B0000087-ST
10 in stock
£38.09 ex VAT
£45.70 inc VAT
The EG3B0000087-ST is a Citrix EG3B0000087 compatible copper transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix EG3B0000087 Compatible SFP Module - 1000BASE-T - 1GE Gigabit Ethernet SFP to RJ45 Cat6/Cat5e Transceiver - 100m - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
Brocade E1MG-TX
6.8 cm x 1.37 cm x 1.38 cm
15 g
Plug-in module
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
100 m
Full duplex mode
1 x Ethernet 1000Base-TX - RJ-45 female
MTBF
510,469,759 hours
FCC, RoHS, REACH, MSA
Brocade E1MG-TX
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Price Range Ex VAT: 0 - 50
