StarTech.com Citrix EG3B0000086 Compatible SFP MM Module - 1000Base-SX
Quicklinx: FJMRWS00 Mfr#: EG3B0000086-ST
The EG3B0000086-ST is a Citrix EG3B0000086 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix EG3B0000086 Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (EG3B0000086-ST) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Citrix EG3B0000086
5.56 cm x 1.37 cm x 1.25 cm
16 g
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MTBF
629,953,711 hours
MSA
Citrix EG3B0000086
5.56 cm
1.37 cm
1.25 cm
16 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
