StarTech.com Citrix 3013936-E2 Compatible QSFP+ MM Module - 40GBase-SR4
Quicklinx: FJB1WS00 Mfr#: 3013936-E2-ST
The 3013936-E2-ST is a Citrix 3013936-E2 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 100 m (328 ft).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix 3013936-E2 Compatible QSFP+ Module, 40GBASE-SR4, Multi Mode (MMF) Fiber, 40GE Gigabit Ethernet QSFP+, MPO Connector, 100 m, 850nm, DDM, 40Gbps QSFP Plus Transceiver - Lifetime Warranty (3013936-E2-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
100 m
Citrix 3013936-E2
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
100 m
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
244,610,582 hours
UL, FCC, RoHS, REACH, MSA
Citrix 3013936-E2
0.7 Watt
Limited warranty - lifetime
