StarTech.com Cisco GLC-ZX-SM-RGD SFP - SM
Quicklinx: CRGDWS00 Mfr#: GLCZXSMRGDST
Add reliable and cost-effective Gigabit Ethernet connections over single-mode fiber with this SFP module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the Cisco GLC-ZX-SM-RGD transceiver module, as well as other major brands of networking equipment.
This 1000Base-ZX SFP delivers Gigabit connectivity over single-mode fiber cable, with a range of up to 70 km (43.5 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This single-mode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-ZX-SM-RGD transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports single-mode fiber cable with a maximum distance of 70 km or 43.5 mi., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
StarTech.com Cisco GLC-ZX-SM-RGD Compatible SFP Module, 1000BASE-ZX, 1GbE SMF Optic Transceiver, LC Connector, 70km, 1550nm, DDM, Cisco ASR920, IE2000IE4000, Mini GBIC Transceiver Module - Lifetime Warranty (GLCZXSMRGDST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-ZX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1550 nm
1GbE
Max Transfer Distance
70 km
Cisco GLC-ZX-SM-RGD
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-ZX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1550 nm
70 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-ZX - LC single-mode female
UL, FCC, RoHS, MSA
Cisco GLC-ZX-SM-RGD
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
CRGD StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £26.11
CRGD StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.49
CRGD StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £26.56
CRGD StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.89
CRGD StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.15
CRGD StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £160.38
CRGD StarTech.com Fiber Media Converter - Open In Stock £48.56
CRGD StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £40.06
CRGD StarTech.com Cisco GLC-SX-MMD SFP - MM In Stock £36.91
CRGD StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £368.50
