Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGLCLHSMST Cisco Compatible Gigabit Fiber SFP Transceiver Module SM/MM LC is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade an SFP slot on your Gigabit fiber networking equipment or fiber media converter.
Supporting a 1000Base-LX/LH network with data rates up to 1.25 Gbps, this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. The SFP transceiver supports both single-mode and multi-mode LC ports, with a single-mode distance of 10 km (6.2 mi.) and multi-mode distance of 1.5 km (.9 mi.). Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1300nm single-mode/multi-mode SFP module is compatible with the Cisco GLC-LH-SM transceiver. Also a perfect accessory for the StarTech.com PEX1000SFP PCI Express Open SFP NIC (PEX1000SFP), or ET1110PSE Gigabit POE Open SFP Media Converter (ET1110PSE) products.
- StarTech.com Cisco GLC-LH-SM Compatible SFP Module, 1000BASE-LX/LH, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, Cisco IE3400, IE3300, IE3200, Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFPGLCLHSMST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LH
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- 1.2 cm x 6 cm x 1 cm
- 17 g
- Limited lifetime warranty
- Designed For
- P/N: ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LH
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LH - LC single-mode
- Compatible Slots
- 1 x SFP (mini-GBIC)
- FCC, RoHS, MSA
- 1.2 cm
- 6 cm
- 1 cm
- 17 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- Designed For
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £42.40 |
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.22 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £27.07 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.35 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £21.31 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £18.18 |
StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £24.49 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £26.56 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £19.89 |
StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £22.15 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £160.38 |
StarTech.com Fiber Media Converter - Open | In Stock | £48.56 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £242.93 |
StarTech.com Gb Fiber SFP - Cisco Compatible | In Stock | £40.06 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £286.64 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £368.50 |
