StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC)
Quicklinx: 8M4GWS00 Mfr#: SFPGLCLHSMST
Type: Modules
Hurry, only 2 left in stock!
£39.20 ex VAT
£47.04 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGLCLHSMST Cisco Compatible Gigabit Fiber SFP Transceiver Module SM/MM LC is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade an SFP slot on your Gigabit fiber networking equipment or fiber media converter.
Supporting a 1000Base-LX/LH network with data rates up to 1.25 Gbps, this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. The SFP transceiver supports both single-mode and multi-mode LC ports, with a single-mode distance of 10 km (6.2 mi.) and multi-mode distance of 1.5 km (.9 mi.). Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1300nm single-mode/multi-mode SFP module is compatible with the Cisco GLC-LH-SM transceiver. Also a perfect accessory for the StarTech.com PEX1000SFP PCI Express Open SFP NIC (PEX1000SFP), or ET1110PSE Gigabit POE Open SFP Media Converter (ET1110PSE) products.
StarTech.com Cisco GLC-LH-SM Compatible SFP Module, 1000BASE-LX/LH, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, Cisco IE3400, IE3300, IE3200, Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFPGLCLHSMST) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
1.2 cm x 6 cm x 1 cm
17 g
P/N: ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-LH
GigE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-LH - LC single-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
8M4G StarTech.com Gb MM SFP Fiber Transceiver In Stock £39.85
8M4G StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £12.95
8M4G StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £21.49
8M4G StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.04
8M4G StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.11
8M4G StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £18.33
8M4G StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.04
8M4G StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC) In Stock £39.20
8M4G StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £34.89
8M4G StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £33.45
8M4G StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.71
8M4G StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £29.51
8M4G StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £129.72
8M4G StarTech.com 10 Pt Gigabit Ethernet Switch In Stock £116.51
8M4G StarTech.com Fiber Media Converter - Open In Stock £62.11
8M4G StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £344.22
Type: Modules
Stock Status: In stock
