StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC)
Quicklinx: 8G5PWS00 Mfr#: SFPGESST
Type: Modules
Hurry, only 3 left in stock!
£33.30 ex VAT
£39.96 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGESST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco SFP-GE-S transceiver.
StarTech.com Cisco SFP-GE-S Compatible SFP Module - 1000BASE-SX - 1GE Gigabit Ethernet SFP 1GbE Multimode Fiber MMF Optic Transceiver - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
1.2 cm x 6 cm x 1 cm
17 g
P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Optical Wave Length
850 nm
550 m
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
UL, FCC, RoHS
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
30 - 70%
8G5P StarTech.com Gb MM SFP Fiber Transceiver In Stock £39.85
8G5P StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £15.91
8G5P StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £40.00
8G5P StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £41.04
8G5P StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £33.30
Type: Modules
Price Range Ex VAT: 0 - 50
