Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGLCSXMMST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps, this LC Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco GLC-SX-MM transceiver. Also a perfect accessory for the StarTech.com PCI Express Open SFP NIC (PEX1000SFP), or Gigabit POE Open SFP Media Converter (ET1110PSE) products.
- StarTech.com Cisco GLC-SX-MM Compatible SFP Module - 1000BASE-SX - 1GE Gigabit Ethernet SFP 1GbE Multimode Fiber MMF Optic Transceiver - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 550 m
- 1.2 cm x 6 cm x 1 cm
- 16 g
- Limited lifetime warranty
- Designed For
- P/N: ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- GigE
- 1.25 Gbps
- 850 nm
- 550 m
- Full duplex capability, half duplex mode
- IEEE 802.3z
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- UL, FCC, RoHS, MSA
- 1.2 cm
- 6 cm
- 1 cm
- 16 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 70%
- Designed For
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £39.85 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £15.91 |
StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £40.00 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £41.04 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £35.65 |
