StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m
Quicklinx: 8M4FWS00 Mfr#: SFP10GSRST
Type: Modules
33 in stock
£132.90 ex VAT
£159.48 inc VAT
Add, replace or upgrade SFP+ modules on 10G fiber equipment. The SFP10GSRST Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m (984ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a 10Gb SFP+ Multimode LC port on your fiber networking equipment or fiber media converter.
Supporting data rates up to 11.1 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP+/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant 10GbE SFP+ port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP+ module is compatible with the Cisco SFP-10G-SR transceiver.
StarTech.com Cisco SFP-10G-SR Compatible SFP+ Module - Lifetime Warranty - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
1.2 cm x 6 cm x 1 cm
17 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
300 m
Half duplex mode, full duplex mode, Digital Diagnostics
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
Compatible Slots
1 x SFP+
UL, FCC, RoHS, Laser Class 1, MSA
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
30 - 70%
8M4F StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £12.44
8M4F StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £15.73
8M4F StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £135.46
8M4F StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £17.53
8M4F StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £26.00
8M4F StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £13.95
8M4F StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £19.31
8M4F StarTech.com PCIe 10Gb Fiber Card SFP+ NIC In Stock £147.17
8M4F StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £223.06
8M4F StarTech.com 10GbE Fiber Media Converter In Stock £835.11
8M4F StarTech.com 10G Open SFP+ NIC - PCIe In Stock £159.78
Type: Modules
Price Range Ex VAT: 100 - 150
