Quicklinx: CZCBWS00 Mfr#: CTKRPR
£21.01 ex VAT
£25.21 inc VAT
This tool kit provides all of the essential screwdrivers, bits, tweezers and spudgers, you'll need to repair virtually any smartphone, tablet or laptop. It's the perfect addition to your electronics repair bench, for working on a wide range of mobile devices. Approach your repair with confidence, knowing you have the right tools on hand for all devices from the major technology brands. Save time and frustration with a single tool kit, that has everything you'll need for cell phone, tablet and smartphone repair.
  • Fast and easy screen change
    With two spudger tools as well as a triangle pry-tool and a suction cup that enables you to pry and remove the screen from a tablet or smartphone.
  • A multi-bit screwdriver
    With 16 bits that are suitable for opening the most popular smartphones, tablets and laptops, to remove or replace internal board screws and standoffs.
  • A set of tweezers
    Used for positioning small cables, connectors or chips within the housing of your mobile devices.
  • A SIM card ejector pin
    That enables you to remove SIM cards from smartphones and tablets.
  • A convenient hard-shelled storage case
    That provides a neat and tidy storage solution for all of the included tools.
StarTech.com Cell Phone Repair Kit - with Case - Multipurpose - Computer Tool Kit - Electronics Kit - PC Tool Kit (CTKRPR) - mobile phone repair tool set - 23 pieces
Mobile phone repair tool set - 23 pieces
Package Content
Screwdriver handle, tweezers, 4 screwdriver bits - phillips PH000, PH00, PH0, PH1, 2 spudgers, suction cup, 2 screwdriver bits - tri-wing TRI0, TRI1, SIM card eject tool, 3 screwdriver bits - pentalobe 0.8, 1.2, 1.6 mm, 5 screwdriver bits - torx T4, T5, T6, T8, T10, triangular pry tool, screwdriver bit - slot 2 mm, screwdriver bit - hex 2 mm
Holder
Case
Tool Set (pieces)
23
Package Content
Holder
Case
Warranty
2 years
10.8 cm
17.1 cm
4.1 cm
295 g
CZCB StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case In Stock £13.88
CZCB StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit In Stock £20.00
CZCB StarTech.com 20-Bit Electric Precision Screwdriver Set In Stock £49.31
CZCB StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £65.01
CZCB StarTech.com 23x47in Anti Static Mat In Stock £48.18
CZCB StarTech.com 11x18in Anti Static Mat In Stock £27.55
Device Type: Smartphone
Type: Repair kit
Product Range: StarTech.com
Product Model: Cell Phone Repair Kit - with Case - Multipurpose - Computer Tool Kit - Electronics Kit - PC Tool Kit (CTKRPR)
