StarTech.com Car Charger - Micro USB & USB
Quicklinx: B686WS00 Mfr#: USBUB2PCARB
32 in stock
£10.25 ex VAT
£12.30 inc VAT
Charge two tablets simultaneously, using your car charge port and our high-powered charger. Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination?
Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
You can charge any Micro USB device, including your tablet or phone, using this convenient 2-in-1 adapter. Plus, since the cable is attached directly to the charger, it won't ever get lost in your vehicle, or be just out of reach while you're driving.
The integrated USB 2.0 port gives you the option to charge an additional mobile device such as your iPad or iPhone, at the same time.
Don't have an Apple device? You can also charge Micro USB or Mini USB-enabled mobile devices with this adapter, such as a smartphone, tablet, or GPS using a USBHAUBMB1MW Mini/Micro USB cable.
No matter what you choose to charge, you can always be sure you have the correct charge available for all your mobile devices.
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time or charging a phone and a tablet, you can be sure all of you mobile devices are ready when you need them.
StarTech.com 2 Port Car Charger w/ Micro USB Cable & USB 2.0 Port 21W/4.2A car power adapter - USB, Micro-USB Type B - 21 Watt
Car power adapter
50 g
Output Connector Type
Total 2: USB, Micro-USB Type B - on cable: Micro-USB
12 - 24 V
Voltage Provided
5 V
Max Electric Current
4.2 A
Power Provided
21 Watt
Power Device Details
- 4 pin USB Type A - 2.1 A , - 5 pin Micro-USB Type B - 2.1 A
Cables
Micro-USB charge cable
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Car power adapter
Tablet, mobile phone
50 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A, 5 pin Micro-USB Type B
Power Provided
21 Watt
Detachable Cable Connector Type
Micro-USB Type B
4.2 A
4 pin USB Type A - 2.1 A , 5 pin Micro-USB Type B - 2.1 A
Coiled
FCC, RoHS
B686 StarTech.com Micro USB to Mini USB Adapter In Stock £4.98
B686 StarTech.com Mini USB to Micro USB Adapter In Stock £4.98
B686 StarTech.com 6in Micro USB Cable - A to Micro B In Stock £3.70
B686 StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F In Stock £6.02
B686 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.64
B686 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.74
B686 StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £19.06
B686 StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £26.23
B686 StarTech.com Car Charger - Micro USB & USB In Stock £10.25
B686 StarTech.com Car Charger - Lightning & USB In Stock £26.40
B686 StarTech.com 6ft Angled Lightning/USB Cable In Stock £15.60
B686 StarTech.com 6ft Right Angle Micro-USB Cable In Stock £4.88
B686 StarTech.com 3ft Micro-USB Charging Cable In Stock £4.10
B686 StarTech.com 3 ft Micro-USB Charging Cable In Stock £4.43
B686 StarTech.com 3 ft Angled Lightning Cable In Stock £13.04
B686 StarTech.com 6 ft Micro-USB Charging Cable In Stock £6.73
B686 StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £10.89
B686 StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.44
B686 StarTech.com 0.5m Angled Micro USB Cable In Stock £4.17
Stock Status: In stock
