StarTech.com Car Charger - Micro USB & USB
Quicklinx: B685WS00 Mfr#: USBUB2PCARW
Charge two tablets simultaneously, in your car. Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination?
Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
You can charge any Micro USB device, including your tablet or phone, using this convenient 2-in-1 adapter. Plus, since the cable is attached directly to the charger, it won't ever get lost in your vehicle, or be just out of reach while you're driving.
The integrated USB 2.0 port gives you the option to charge an additional mobile device such as your iPad or iPhone, at the same time.
Don't have an Apple device? You can also charge Micro USB or Mini USB-enabled mobile devices with this adapter, such as a smartphone, tablet, or GPS using a USBHAUBMB1MW Mini/Micro USB cable.
No matter what you choose to charge, you can always be sure you have the correct charge available for all your mobile devices.
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time or charging a phone and a tablet, you can be sure all of you mobile devices are ready when you need them.
StarTech.com Dual Port Car Charger with Micro USB Cable and USB Port - High Power (21 Watt / 4.2 Amp) - Dual Tablet Car Charger - White (USBUB2PCARW) car power adapter - USB, Micro-USB Type B - 21 Watt
Car power adapter
50 g
White
Output Connector Type
Total 2: USB, Micro-USB Type B - on cable: Micro-USB
12 - 24 V
Voltage Provided
5 V
Max Electric Current
4.2 A
Power Provided
21 Watt
Power Device Details
- 4 pin USB Type A - 2.1 A , - 5 pin Micro-USB Type B - 2.1 A
Cables
Micro-USB charge cable
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Car power adapter
Tablet, mobile phone
50 g
Enclosure Colour
White
12 - 24 V
Input Connectors
Automobile cigarette lighter
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A, 5 pin Micro-USB Type B
Power Provided
21 Watt
Detachable Cable Connector Type
Micro-USB Type B
4.2 A
4 pin USB Type A - 2.1 A , 5 pin Micro-USB Type B - 2.1 A
Coiled
FCC, RoHS
