Your basket is empty
StarTech.com Car Charger - Micro USB & USB
Quicklinx: B686WS00 Mfr#: USBUB2PCARB
More than 50 in stock
£12.36 ex VAT
£14.83 inc VAT
Standard delivery Delivered within 3-5 working days
Charge two tablets simultaneously, using your car charge port and our high-powered charger. Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination?
Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
You can charge any Micro USB device, including your tablet or phone, using this convenient 2-in-1 adapter. Plus, since the cable is attached directly to the charger, it won't ever get lost in your vehicle, or be just out of reach while you're driving.
The integrated USB 2.0 port gives you the option to charge an additional mobile device such as your iPad or iPhone, at the same time.
Don't have an Apple device? You can also charge Micro USB or Mini USB-enabled mobile devices with this adapter, such as a smartphone, tablet, or GPS using a USBHAUBMB1MW Mini/Micro USB cable.
No matter what you choose to charge, you can always be sure you have the correct charge available for all your mobile devices.
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time or charging a phone and a tablet, you can be sure all of you mobile devices are ready when you need them.
StarTech.com 2 Port Car Charger w/ Micro USB Cable & USB 2.0 Port 21W/4.2A - power adapter - car
Power adapter - car
50 g
Output Connector Type
USB (power only), Micro-USB Type B (power only) - on cable: Micro-USB
12 - 24 V
Voltage Provided
5 V
2 years warranty
Power adapter - car
50 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A (power only), 5 pin Micro-USB Type B (power only)
Power Provided
21 Watt
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
4.2 A
Output Details
4 pin USB Type A (power only) - 2.1 A , 5 pin Micro-USB Type B (power only) - 2.1 A
Coiled
Micro-USB charge cable
FCC, RoHS
Price Range Ex VAT: 0 - 50
