StarTech.com Car Charger - Lightning & USB
Quicklinx: B687WS00 Mfr#: USBLT2PCARB
Colours:
Hurry, only 2 left in stock!
£25.85 ex VAT
£31.02 inc VAT
Charge two iPad tablets simultaneously, using your car charge port and the high-powered charger. Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination?
Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
You can charge any Lightning mobile device, including your iPad or iPhone, using this convenient 2-in-1 adapter. Plus, since the cable is attached directly to the charger, it won't ever get lost in your vehicle, or be just out of reach while you're driving.
The integrated USB port gives you the option to charge an additional Apple device, including a second iPad, at the same time.
Don't have a second Apple device? You can also charge Micro USB or Mini USB-enabled mobile devices with this adapter, such as a smartphone, tablet, or GPS using a USBHAUBMB1MW Mini/Micro USB cable.
No matter what you choose to charge, you can always be sure you have the correct charge available for all your mobile devices.
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time or charging a phone and a tablet, you can be sure all of your mobile devices are ready when you need them.
StarTech.com 2 Port Car Charger w/ Lightning Cable & USB 2.0 Port 21W/4.2A car power adapter
Car power adapter
3.5 cm x 34 cm x 2.5 cm
50 g
Output Connector Type
USB, Lightning
12 - 24 V
Voltage Provided
5 V
Cables
Lightning cable
Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Car power adapter
3.5 cm
34 cm
2.5 cm
50 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A, Apple Lightning
Power Provided
21 Watt
Max Electric Current
4.2 A
Lightning cable
Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
StarTech.com Car Charger - Lightning & USB Bundle deal on StarTech.com Car Charger - Lightning & USB
£125.02
B687 StarTech.com 0.3m (1ft) Coiled Black Apple 8-pin Lightning Connector to USB Cable iPhone iPodiPad In Stock £10.51
B687 StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £25.84
B687 StarTech.com Car Charger - Micro USB & USB In Stock £10.12
B687 StarTech.com Car Charger - Lightning & USB In Stock £25.85
Price Range Ex VAT: 0 - 50
