StarTech.com Brocade XBR-000190 Comp SFP Copper Module - 10/100/1000
Quicklinx: FJPDWS00 Mfr#: XBR-000190-ST
10 in stock
£37.03 ex VAT
£44.43 inc VAT
The XBR-000190-ST is a Brocade XBR-000190 compatible copper transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000 compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Brocade XBR-000190 Compatible SFP Module - 1000BASE-T - 1GE Gigabit Ethernet SFP to RJ45 Cat6/Cat5e Transceiver - 100m - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
Brocade XBR-000190
6.8 cm x 1.37 cm x 1.37 cm
15 g
Brocade 7800 Extension Switch; VDX 6720, 6730, 6740, 6740T, 6740T-1G
Plug-in module
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
100 m
Full duplex mode
1 x Ethernet 1000Base-T - RJ-45 female
MTBF
510,469,759 hours
FCC, RoHS, REACH, MSA
Brocade XBR-000190
6.8 cm
1.37 cm
1.37 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Brocade 7800 Extension Switch , Brocade VDX 6720, 6730, 6740, 6740T, 6740T-1G
Stock Status: In stock
