StarTech.com Brocade 10G-SFPP-LRM Compatible SFP+ MM Module - 10GBase-LRM
Quicklinx: FJ9RWS00 Mfr#: 10G-SFPP-LRM-ST
£104.95 ex VAT
£125.94 inc VAT
The 10G-SFPP-LRM-ST is a Brocade 10G-SFPP-LRM compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Brocade 10G-SFPP-LRM Compatible SFP+ Module - 10GBASE-LRM - 10GE SFP+ 10GbE Multimode Fiber MMF Optic Transceiver - 200m DDM - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-LRM
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
200 m
5.84 cm x 1.39 cm x 1.37 cm
21 g
Plug-in module
Wired
Cabling Type
10GBase-LRM
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
200 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
MTBF
145,858,878 hours hours
FCC, MSA
1 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Stock Status: In stock
