StarTech.com Black Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad
Quicklinx: 95RBWS00 Mfr#: USBUBLTB
Length: 10.15cm
Colours:
18 in stock
£13.21 ex VAT
£15.85 inc VAT
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTB Lightning to Micro USB dongle for iPhone, iPod, iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your Apple mobile digital devices using a Micro USB cable.
The dongle offers approximately 4-inches in cable length, which lessens strain on the connector port and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable adapter is Apple MFi certified.
StarTech.com Black Micro USB to Lightning Adapter for iPhone iPod iPad - Lightning adapter - Lightning / USB - 10.15 cm
Cable
Shielded
American Wire Gauge (AWG)
24/28/32
Length
10.15 cm
Connector
Lightning - male
Connector (Second End)
Micro-USB Type B - female
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Shielded
24/28/32
Jacket Material
PVC
Shielding Material
Length
10.15 cm
Connector
Apple Lightning - male
5 pin Micro-USB Type B - female
95RB StarTech.com Black Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad In Stock £13.21
95RB StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad In Stock £13.52
Length: 10.15cm
Price Range Ex VAT: 0 - 50
