StarTech.com Arista Networks AR-SFP-10G-T Comp SFP Copper Module
Quicklinx: FJBHWS00 Mfr#: AR-SFP-10G-T-ST
£180.60 ex VAT
£216.72 inc VAT
The AR-SFP-10G-T-ST is an Arista Networks SFP-1G-T compatible copper transceiver module that has been designed, programmed and tested to work with Arista Networks brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 100/1000/10000Base-TX compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Arista Networks AR-SFP-10G-T Compatible SFP+ Module, 10GBASE-T, SFP+ to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, Mini GBIC Transceiver SFP Plus Module - Lifetime Warranty (AR-SFP-10G-T-ST) - SFP (mini-GBIC) transceiver module - 10 GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10 GigE
Max Transfer Distance
30 m
6.8 cm x 1.37 cm x 1.38 cm
15 g
Plug-in module
Wired
Cabling Type
10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
30 m
Full duplex mode
IEEE 802.3ae
1 x Ethernet 10GBase-T - RJ-45 female
MTBF
510,469,759 hours
FCC, RoHS, REACH, MSA
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
