Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTADPB Lightning to Micro USB adapter for iPhone, iPod, iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your Apple Lightning devices using a Micro USB cable.
This compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables you need to carry around with you in order to charge all of your mobile devices.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable Lightning to Micro USB adapter is Apple MFi certified.
- StarTech.com Black Apple 8-pin Lightning Connector to Micro USB Adapter for iPhone / iPod / iPad - Apple Lightning to Micro USB Adapter (USBUBLTADPB) - Lightning adapter - Lightning / USB
- Cable
- Black
- Connector
- Micro-USB Type B - female
- Connector (Second End)
- Lightning - male
- 2-year warranty
- Cable Type
- Lightning adapter
- Interface Supported
- Lightning / USB
- Plated Connector
- Nickel
- Black
- Connector
- 5 pin Micro-USB Type B - female
- Apple Lightning - male
- RoHS, MFI
- Limited warranty - 2 years
