Easily mount any DIN Rail equipment in a standard 19" rack. The ADJDINKIT Adjustable Rack Mount DIN Rail Kit with Top Hat/Mini/G Rails makes mounting your DIN-rail equipment in a 19-inch server rack/cabinet or wall plate simple, without wasting space due to special bracket requirements for each piece of equipment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
This 19-inch DIN Rail Mounting Kit includes the three most commonly used DIN rail systems: Top-Hat, Miniature Top-Hat, and G-Type.
- StarTech.com 2U DIN Rail Kit for Standard 19" Rack - Adjustable Depth Rackmount DIN Rail with Top Hat, Mini, G Rails (ADJDINKIT) - rack rail kit - 2U
- Product Type
- Rack rail kit
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Steel
- 48.3 cm x 35.8 cm x 8.9 cm
- 1.72 kg
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK4OD, RK619WALL, RK619WALLGB, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Rack rail kit
- Product Material
- Steel
- Rack Size
- 19"
- 2U
- 48.3 cm
- 35.8 cm
- 8.9 cm
- 1.72 kg
- Black
- Mounting Kit
- Included
- UL, RoHS
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK4OD, RK619WALL, RK619WALLGB, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £99.95 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.70 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.41 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.78 |
StarTech.com 19in Cable Management Panel | In Stock | £23.35 |
