StarTech.com 95mm Socket T 775 CPU Cooler Fan with Heatsink
Quicklinx: 6BF2WS00 Mfr#: FAN775E
Type: CPU Cooler
25 in stock
£9.85 ex VAT
£11.82 inc VAT
Provide a fan and heatsink cooling solution to any standard socket 775/T desktop CPU. This socket T/775 cooler is designed specifically for the Intel socket 775 (socket T) range of processors, including Intel Core 2 Duo and Intel Core 2 Quad, Core 2 Duo Extreme CPUs.
The CPU cooler features a large aluminum heatsink that maximizes dissipation of the heat around the CPU, as well a low-noise 95mm fan that provides up to 50 cfm of air circulation, helping to keep the CPU cooler for optimized performance.
The socket 775/T cooler/fan offers simple installation, providing tool-less clips for easy connection to the motherboard.
The socket 775/socket T CPU cooler is a dependable, high quality CPU cooling solution.
StarTech.com 95mm Socket T 775 CPU Cooler Fan with Heatsink - socket 775 cooler - lga 775 cooler - 775 cpu cooler (FAN775E) processor cooler
Processor cooler
Compatibility
LGA775 Socket
Heatsink Material
Aluminium
Fan Diameter
95 mm
Fan Height
25 mm
Fan Bearing
Ever Lubricate bearing
Rotation Speed
2800 rpm
Air Flow
49.4 cfm
Power Connector
3-pin plug
9.5 cm x 9.5 cm x 6.8 cm
374 g
Processor cooler
9.5 cm
9.5 cm
6.8 cm
374 g
Heatsink & Fan
Compatible With
LGA775 Socket
Heatsink Material
Aluminium
Fan Diameter
95 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
2800 rpm
Air Flow
49.4 cfm
Power Connector
3-pin plug
RoHS
Sound Emission
22.2 dBA
Type: CPU Cooler
Price Range Ex VAT: 0 - 50
