StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
Quicklinx: 403PWS00 Mfr#: FANBOX92
Type: Case Fan
16 In Stock
£5.77 ex VAT
£6.92 inc VAT
This 9.2cm x 9.2cm x 2.5cm (3 5/8" x 3 5/8" x 1") dual ball bearing PC case fan is an add-in cooling fan designed to fit most computers. The PC case fan can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components.
A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 39.35 CFM (cubic feet per minute) of air.
Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - 90mm Fan - computer case Fan - pc Fan (FANBOX92) - system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
32 dB
9.2 cm x 2.5 cm x 9.2 cm
1-year warranty
System fan kit
9.2 cm
2.5 cm
9.2 cm
Heatsink & Fan
Fan Diameter
92 mm
Noise Level
32 dB
Limited warranty: - 1 year - carry-in
403P StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector In Stock £5.77
403P StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector In Stock £6.57
403P StarTech.com Mounting PC Case Fan Screws - 50 Pack In Stock £2.72
403P StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.36
Type: Case Fan
