StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan with TX3 Connector
Clearance!
Clearance
Last Few Remaining
Quicklinx: 403VWS00 Mfr#: FAN9X25TX3L
Type: Case Fan
24 in stock
£5.93 ex VAT
£7.11 inc VAT
Keeping a computer cooled is the best way to increase its efficiency and power. A quiet-running fan can ensure that your computer runs smoothly without disruptive, noisy operation.
StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan w/ TX3 Connector system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
25 dBA
9.2 cm x 2.5 cm x 9.2 cm
System fan kit
9.2 cm
2.5 cm
9.2 cm
Security Cable Lock
Fan Diameter
92 mm
Noise Level
25 dBA
Limited warranty - 2 years - carry-in
Type: Case Fan
Price Range Ex VAT: 0 - 50
