StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
Quicklinx: 9CQ6WS00 Mfr#: FAN9X25TX3H
Type: Case Fan
18 in stock
£6.91 ex VAT
£8.29 inc VAT
Keeping a computer cooled is the best way to increase its efficiency and power. A high-airflow fan can ensure that your computer runs smoothly and is kept at a constantly lower temperature than with normal fans. High airflow circulates hot air around the case and exhausts it out the back.
StarTech.com High Flow Case Fan with TX3 Connector system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
33 dBA
1-year warranty
System fan kit
Security Cable Lock
Fan Diameter
92 mm
Noise Level
33 dBA
Limited warranty - 1 year
Type: Case Fan
Price Range Ex VAT: 0 - 50
