StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
Quicklinx: 9CQ6WS00 Mfr#: FAN9X25TX3H
Type: Case Fan
£7.25 ex VAT
£8.70 inc VAT
Keeping a computer cooled is the best way to increase its efficiency and power. A high-airflow fan can ensure that your computer runs smoothly and is kept at a constantly lower temperature than with normal fans. High airflow circulates hot air around the case and exhausts it out the back.
StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 (FAN9X25TX3H) - system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
33 dBA
1-year warranty
System fan kit
Heatsink & Fan
Fan Diameter
92 mm
Noise Level
33 dBA
Limited warranty: - 1 year
Type: Case Fan
