Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK819WALLOH 8U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 8U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
- StarTech.com 8U Hinged Open Frame Wall Mount Network Rack - 4-Post 22" Depth Swing Out Computer Equipment Rack - 140lbs capacity (RK819WALLOH) rack - 8U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 22"
- Height (Rack Units)
- 8U
- Product Material
- Cold-rolled steel
- 60.4 cm x 55.5 cm x 48.8 cm
- 15.1 kg
- Hinged
- Limited lifetime warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Cold-rolled steel
- Rack Size
- 22"
- 8U
- 60.4 cm
- 55.5 cm
- 48.8 cm
- 15.1 kg
- Black
- Weight Limit
- 63.4 kg
- Mounting Kit
- Included
- Hinged
- EIA-310-D, UL, RoHS
- Limited warranty - lifetime
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £112.36 |
StarTech.com 12U 19in Wall Mount Side Mount Open Frame Rack Cabinet | In Stock | £258.57 |
StarTech.com 8U 19in Wall Mount Side Mount Open Frame Rack Cabinet | In Stock | £251.02 |
