Mount your server and networking equipment to the wall, with side mounting for hassle-free access to rear cabling. The RK819SIDEM Side-mounted Wallmount Open Frame Rack/Cabinet is an 8U server rack that lets you mount your (19-inch wide) servers, A/V or network equipment facing perpendicular to the wall, for easy access to mounted devices and equipment. The cabinet/rack features open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed. Plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks, without causing an obstruction. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame equipment rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
- StarTech.com 8U Open Frame Wall Mount Rack - Sideways Wall Mount IT Equipment Rack Cabinet - 20.8 in Depth Server Room Rack (RK819SIDEM) - rack - 8U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 8U
- Product Material
- Steel
- 53.7 cm x 56 cm x 47.8 cm
- 17.7 kg
- Limited lifetime warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 8U
- 53.7 cm
- 56 cm
- 47.8 cm
- 17.7 kg
- Black
- Weight Limit
- 159 kg
- Mounting Kit
- Included
- EIA-310-D, UL, RoHS
- Limited warranty: - lifetime
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.35 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.08 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £28.56 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £26.26 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £49.79 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.66 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £23.53 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £123.73 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £80.80 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £100.69 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £14.41 |
StarTech.com 12U 22in Depth Hinged Open Frame Wall Mount Server Rack | In Stock | £270.43 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £3.88 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £5.93 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £35.88 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £43.84 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.75 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £21.49 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £52.61 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £28.05 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £18.78 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £8.88 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.01 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £49.80 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £26.28 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £27.61 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £15.40 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £25.11 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £25.21 |
StarTech.com 19in Cable Management Panel | In Stock | £22.13 |
StarTech.com 12U Wall Mount Server Rack | In Stock | £61.40 |
StarTech.com 15U Wall Mount Server Rack | In Stock | £76.82 |
StarTech.com 15U Wall-Mount Server Rack | In Stock | £105.89 |
StarTech.com 12U Wall-Mount Server Rack | In Stock | £105.03 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £15.40 |
