Need to connect your Mini HDMI equipped laptop or tablet to a DVI-D digital display? This 8in Mini HDMI to DVI adapter provides the perfect solution.
High-resolution 1920x1200 video support
Connect your Mini HDMI capable laptop or tablet to a DVI digital monitor, TV or projector, and share your presentations, pictures and videos. Simply plug in any one of our male-to-male DVI-D cables, such as our 3ft DVI-D single-link cable (DVIMM3) into the adapter and connect the adapter to your device. Perfect for use in a boardroom, your home office or when travelling for work, you can be ready to connect wherever you are. Need a way to incorporate audio into your presentation? You can use our 1m 3.5mm audio cable (MU3MMS). -
8-inch cable reduces port damage
Reduce stress and prevent damage on the device port. The 8-inch cable design reduces the strain on the port as well as the connectors, plus it doesn't block other open ports, leaving them open for connecting other devices. -
Compact and lightweight design
The adapter fits nicely inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory to keep in your carry-on baggage. Arrive prepared when presenting to a potential client, teaching offsite, or travelling to a customer location. The HDCDVIMF8IN Mini HDMI to DVI adapter is backed by StarTech.com's lifetime warranty.
- StarTech.com 8 in Mini HDMI to DVI Cable Adapter, DVI-D to HDMI (1920x1200p), 19 Pin HDMI Mini (C) Male to DVI-D Female, Digital Monitor Adapter Cable M/F, 3.9 Gbps Bandwidth, Black - Mini HDMI to DVI Adapter - adapter - HDMI / DVI - 20.32 cm
- Cable
- Adapter - HDMI / DVI
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 30/32
- Length
- 20.32 cm
- Black
- Connector
- DVI-D - female
- Connector (Second End)
- 19 pin mini HDMI Type C - male
- Limited lifetime warranty
- Cable Type
- Adapter
- Interface Supported
- HDMI / DVI
- Technology
- Double shielded
- 30/32
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 20.32 cm
- Plated Connector
- Gold
- Black
- Connector
- 24+1 pin digital DVI - female
- RoHS
- Limited warranty - lifetime
