StarTech.com 8in Micro HDMI to DVI Adapter
Quicklinx: BFPMWS00 Mfr#: HDDDVIMF8IN
£11.23 ex VAT
£13.47 inc VAT
Connect a DVI display to a Micro HDMI enabled device using a standard DVI-D cable. Need to connect your Micro HDMI equipped phone or laptop to a DVI-D digital display? This 8-inch Micro HDMI to DVI adapter provides the perfect solution.
Connect your Micro HDMI laptop or mobile device to a DVI-digital monitor or projector. Simply plug any male-to-male DVI-D cable, such as DVIMM3 3ft DVI-D single-link cable (DVIMM3) from the display into the adapter and connect the adapter to your device.
Perfect for use in a boardroom, your home office or when traveling for work, you can be ready to present wherever you are.
Reduce stress and prevent damage on the device port. This 8-inch cable extends the device port away from your computer, which helps prevent damage by reducing strain on the port as well as the connectors. Plus, it doesn't block other open ports, leaving them open for connecting your other devices.
The adapter fits nicely inside your laptop bag, backpack or other carrying case, making it the perfect mobile accessory to keep in your carry-on baggage. Arrive prepared when you're presenting to a potential client, teaching offsite, or traveling to a customer location.
  • Share your presentations, pictures and videos
    Connect your Micro HDMI laptop or mobile device to a DVI-digital monitor or projector. Simply plug any male-to-male DVI-D cable, such as our 3ft DVI-D single-link cable (DVIMM3) from the display into the adapter and connect the adapter to your device. Perfect for use in a boardroom, your home office or when travelling for work, you can be ready to present wherever you are. Need a way to include audio in your presentations? You can use our 1m 3.5mm audio cable (MU3MMS).
  • Reduce strain on your device port
  • Arrive prepared wherever you go
    The adapter fits nicely inside your laptop bag, backpack or other carrying case, making it the perfect mobile accessory to keep in your carry-on baggage. Arrive prepared when you're presenting to a potential client, teaching offsite, or travelling to a customer location. The HDDDVIMF8IN Micro HDMI to DVI adapter is backed by StarTech.com's lifetime warranty.
StarTech.com 8in Micro HDMI to DVI-D Adapter M/F - 8in Micro HDMI to DVI Cable - Connect a Micro HDMI phone or laptop to a DVI-D display (HDDDVIMF8IN) - adapter - HDMI / DVI - 20.3 cm
Cable
Adapter - HDMI / DVI
Shielded
American Wire Gauge (AWG)
30/32
Length
20.3 cm
Connector
DVI-D - female
Connector (Second End)
19 pin micro HDMI Type D - male
Cable Type
Adapter
Interface Supported
HDMI / DVI
Shielded
30/32
Jacket Material
PVC
Shielding Material
Length
20.3 cm
Plated Connector
Gold
Connector
24+1 pin digital DVI - female
RoHS
Limited warranty - lifetime
BFPM StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.59
BFPM StarTech.com 8in Mini HDMI to DVI adapter In Stock £10.40
BFPM StarTech.com 8" Mini HDMI to DVI adapter In Stock £10.40
BFPM StarTech.com 8in Micro HDMI to DVI Adapter In Stock £11.23
