StarTech.com 8in LFH 59 Male to Female DVI I VGA DMS 59 Cable
Quicklinx: 679ZWS00 Mfr#: DMSDVIVGA1
Type: DVI
Length: 20cm
20 in stock
£14.74 ex VAT
£17.68 inc VAT
Connect one VGA monitor and one DVI monitor to your DMS / LFH graphics card. This DMS 59 to DVI and VGA Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro cards into one DVI-I dual link female connector and one high density DB15 female connector, letting you to connect one VGA monitor and one DVI monitor for a cost-effective dual display solution.
StarTech.com DMS 59 Splitter Cable - 8in - DMS 59 to 1 x DVI / 1 x VGA - Y Cable - DMS 59 to VGA - Monitor Splitter Cable - DMS 59 Cable (DMSDVIVGA1) - display cable - 20 cm
Display cable - dual link
Length
20 cm
Connectors
DMS-59 - male
Connectors (Second End)
HD-15 (VGA) - female , DVI-I - female
RoHS
Display cable
TMDS Links
Dual link
Length
20 cm
Connectors
DMS-59 - male
15 pin HD D-Sub (HD-15) - female , 24+5 pin combined DVI - female
RoHS
Type: DVI
Length: 20cm
Price Range Ex VAT: 0 - 50
