StarTech.com 8in LFH 59 Male to Dual Female DVI I DMS 59 Cable
Quicklinx: 679XWS00 Mfr#: DMSDVIDVI1
More than 50 in stock
£12.60 ex VAT
£15.12 inc VAT
Connect two DVI monitors to your DMS / LFH equipped graphics card.. This DMS 59 to dual DVI Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro graphics cards into two DVI-I Dual Link female connectors - letting you connect two DVI capable monitors for a cost-effective dual monitor solution.
StarTech.com DMS 59 to Dual DVI I - 8in - DMS 59 to 2x DVI - Y Cable - DVI Splitter Cable - Monitor Splitter Cable - DMS 59 Cable (DMSDVIDVI1) - DVI cable - 20 cm
DVI cable - dual link
Length
20 cm
Connector
2 x DVI-I - female
Connector (Second End)
DMS-59 - male
RoHS
DVI cable
TMDS Links
Dual link
Length
20 cm
Connector
2 x 24+5 pin combined DVI - female
DMS-59 - male
RoHS
Price Range Ex VAT: 0 - 50
