Secure latching SATA cable designed for new system boards and SATA hard drives. The LSATA8 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 8in Latching SATA to SATA Cable - F/F - SATA cable - 20 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Latched
- Length
- 20 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB43SATSASB, HSB4SATSASBA, PEXMSATA3422, PEXMSATA343, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425
- Storage Cable Type
- SATA cable
- Interface Speed
- American Wire Gauge (AWG)
- 26
- Latched
- Length
- 20 cm
- Red
- Connector
- RoHS
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25X2, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXMSATA3422, PEXMSATA343, PEXSAT34RH, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
StarTech.com 12in Latching SATA Cable | In Stock | £3.66 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.36 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.66 |
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.69 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £3.79 |
