StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female
Quicklinx: 8FHWWS00 Mfr#: HDDVIMF8IN
Length: 20.32cm
More than 50 in stock
£7.66 ex VAT
£9.19 inc VAT
Connect a DVI-D device to an HDMI-enabled device using a standard HDMI cable. The HDDVIMF8IN HDMI to DVI Cable Adapter features one HDMI male connector and one DVI-D female connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
The HDMI to DVI dongle offers 8-inches in cable length, which lessens strain on the connectors and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
StarTech.com HDMI Male to DVI Female Adapter - 8in - 1080p DVI-D Gender Changer Cable (HDDVIMF8IN) - video adapter - HDMI / DVI - 20.32 cm
Cable
Video adapter - HDMI / DVI
Shielded
American Wire Gauge (AWG)
28
Length
20.32 cm
Connector
HDMI - male
Connector (Second End)
DVI-D - female
P/N: 45PATCH25WH, BNDDKT30CAHV, CDP2DVIMM2MB, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, USB31GEHD, USB3SMDOCKHV
Cable Type
Video adapter
Interface Supported
HDMI / DVI
Shielded
28
Jacket Material
PVC
Shielding Material
Length
20.32 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
24+1 pin digital DVI - female
RoHS
Limited warranty - lifetime
8FHW StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.17
8FHW StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.55
8FHW StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £7.55
8FHW StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.68
8FHW StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £7.43
8FHW StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £7.66
Length: 20.32cm
Price Range Ex VAT: 0 - 50
